Einleitung
Remove the logic board assembly from your mini.
Was du brauchst
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
Firmly grasp the sleep light cable connector with a pair of tweezers and lift it straight up off the logic board.
Remove the single T10 torx lug securing the logic board to the bottom housing.
Use the flat end of a spudger to slightly lift the logic board near the PRAM battery to separate it from the bottom housing.
Gently lift the free end of the logic board and wiggle the board as you pull it away from the I/O ports.
