Einleitung
Internal Prereq for battery removal when fan is out.
Was du brauchst
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Fast fertig!
Abschluss
