Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the battery.
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  1. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. In this step you will disconnect the battery to help avoid shorting out any components during service. Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  3. Remove the following five screws securing the battery to the upper case:
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  4. When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Abschluss
64 weitere Nutzer haben diese Anleitung absolviert.
Sam Goldheart
439.529 Reputation
547 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
138 Mitglieder
16.442 Anleitungen geschrieben
Reminder: Crimp the new battery’s ribbon cable before you screw it in so that you’ll have an easier time connecting it to the power terminal.
Andrew Harris - Antwort
That was too easy. After dealing with the glue and all the zif cables to replace the battery on a MacBook, this was just an easy breeze.
Steve Heffern - Antwort
Followed instructions, but MacAir lost gattery icon and will not charge replaced battery, despite SCO reboot and recheck on battery connector
russellseitz - Antwort
the battery I purchased has the battery connector in a different spot…it’s to the left…can it be slid over to the correct position?
Kirstie - Antwort
installed but now the macbook air trackpad ‘clicks’ when then touch it as if it’s slightly loose (it doesn’t physically do a click)
naquada - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 17
Letzten 7 Tage: 104
Letzten 30 Tage: 453
Insgesamt: 38,623
