Einleitung
prereq for removing IO board side display screws and heatsink screw
Was du brauchst
Remove the two 5.6 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
Push the antenna cable retainer out of the way and remove the single 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
Fast fertig!
Abschluss
