Zum Hauptinhalt wechseln
MacBook Air 13" Early 2020 Lower Case Replacement
Was du brauchst
  1. MacBook Air 13" Early 2020 Lower Case Replacement, Remove the screws securing the lower case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Lower Case Replacement, Remove the lower case: Schritt 2, Bild 1 von 3 MacBook Air 13" Early 2020 Lower Case Replacement, Remove the lower case: Schritt 2, Bild 2 von 3 MacBook Air 13" Early 2020 Lower Case Replacement, Remove the lower case: Schritt 2, Bild 3 von 3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Carsten Frauenheim
113.322 Reputation
338 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.816 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 59
Letzte 30 Tage: 215
Insgesamt: 5,331
