Einleitung
Hier wird der Austausch des Mikrofons gezeigt.
  • Bevor du anfängst, fahre dein Gerät herunter. Schließe das Display und lege es umgekehrt auf eine weiche Oberfläche.
  • Entferne die folgenden zehn Schrauben:
    • Zwei 9 mm Pentalobe P5 Schrauben
    • Acht 2,6 mm Pentalobe P5 Schrauben
  • Der Spezialschraubenzieher, der zum Entfernen der zehn 5-Punkt Pentalobe Schrauben benötigt wird, ist hier erhältlich.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Antwort
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Antwort
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Antwort
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Antwort
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Antwort
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Antwort
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Antwort
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Antwort
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Antwort
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Antwort
Löse das hintere Gehäuse vom Air, indem du mit den Fingerspitzen zwischen Display und Gehäuse gehst und es nach oben ziehst.
  • Löse das hintere Gehäuse vom Air, indem du mit den Fingerspitzen zwischen Display und Gehäuse gehst und es nach oben ziehst.
  • Entferne das hintere Gehäuse und lege es beiseite.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Antwort
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Antwort
Fasse die durchsichtige Plastiklasche, die am Akkuanschluss angebracht ist, an und ziehe sie in Richtung des vorderen Rands des Air, um den Akku vom Logic Board zu trennen. Ziehe dabei den Verbinder keinesfalls nach oben!
  • Fasse die durchsichtige Plastiklasche, die am Akkuanschluss angebracht ist, an und ziehe sie in Richtung des vorderen Rands des Air, um den Akku vom Logic Board zu trennen.
  • Ziehe dabei den Verbinder keinesfalls nach oben!
Kommentar hinzufügen
Entferne folgende fünf Torx T5 Schrauben, die den Akku am Gehäuse befestigen:
  • Entferne folgende fünf Torx T5 Schrauben, die den Akku am Gehäuse befestigen:
    • Drei 6,3 mm Schrauben
    • Zwei 2,4 mm Schrauben
When going in reverse, it's easier to do step 3 before 4.
John Heffernan - Antwort
Wenn du am Akku arbeitest, vermeide es die vier offenliegenden Lithium Polymerzellen anzufassen oder zu drücken.
  • Wenn du am Akku arbeitest, vermeide es die vier offenliegenden Lithium Polymerzellen anzufassen oder zu drücken.
  • Hebe den Akku an der Kante an, die dem Logic Board am nächsten ist, und entferne ihn aus dem Gehäuse.
  • Wenn du einen neuen Akku einbaust:
    • Du solltest deinen Akku vor dem ersten Gebrauch kalibrieren: Lasse ihn über Nacht leer werden, lade ihn dann auf 100% auf und lasse ihn wieder leer werden, bis er automatisch abschaltet. Nach erneutem Aufladen kannst du ihn normal benutzen.
    • Wenn du ein ungewöhnliches Verhalten oder Probleme nach dem Akkuwechsel bemerkst, dann hilft vielleicht ein Rücksetzen des SMC (System Management Controller) deines MacBook Pro.
Hebele den Stecker am Kabel zum linken Lautsprecher mit dem flachen Ende des Spudgers hoch und aus seinem Anschluss auf dem I/O Board heraus.
  • Hebele den Stecker am Kabel zum linken Lautsprecher mit dem flachen Ende des Spudgers hoch und aus seinem Anschluss auf dem I/O Board heraus.
  • Hebele unter den Drähten.
How can I order that ribbon cable that goes over the fan housing?
Chris Maki - Antwort
Löse den linken Lautsprecher mit dem flachen Ende des Spudgers aus der Klebeverbindung zum oberen Gehäuse. Entferne den linken Lautsprecher aus dem oberen Gehäuse. Entferne den linken Lautsprecher aus dem oberen Gehäuse.
  • Löse den linken Lautsprecher mit dem flachen Ende des Spudgers aus der Klebeverbindung zum oberen Gehäuse.
  • Entferne den linken Lautsprecher aus dem oberen Gehäuse.
Heble den Stecker am Kabel zum I/O Board aus seinem Anschluss auf dem I/O Board. Du brauchst das Kabel zum I/O Board nicht zu entfernen, biege es einfach aus dem Weg.
  • Heble den Stecker am Kabel zum I/O Board aus seinem Anschluss auf dem I/O Board.
  • Du brauchst das Kabel zum I/O Board nicht zu entfernen, biege es einfach aus dem Weg.
  • Löse das Kabel zu I/O Board vorsichtig aus der Klebeverbindung zur Oberseite des Lüfters, entferne es aber nicht.
Kippe den Sicherungsbügel am ZIF Anschluss des Flachbandkabels zum Mikrofon mit der Spudgerspitze hoch. Achte darauf, dass du nur am Sicherungsbügel hebelst, nicht am Anschluss selbst. Schiebe das Mikrofonkabel vorsichtig aus seinem Anschluss auf dem I/O Board.
  • Kippe den Sicherungsbügel am ZIF Anschluss des Flachbandkabels zum Mikrofon mit der Spudgerspitze hoch.
  • Achte darauf, dass du nur am Sicherungsbügel hebelst, nicht am Anschluss selbst.
  • Schiebe das Mikrofonkabel vorsichtig aus seinem Anschluss auf dem I/O Board.
Hebele das Mikrofon mit der Spudgerspitze aus der Klebeverbindung zur linken Seite des oberen Gehäuses. Entferne das Mikrofon vom oberen Gehäuse. Entferne das Mikrofon vom oberen Gehäuse.
  • Hebele das Mikrofon mit der Spudgerspitze aus der Klebeverbindung zur linken Seite des oberen Gehäuses.
  • Entferne das Mikrofon vom oberen Gehäuse.
i want this product where can find it ?
the Microphone
Waseem Rifai - Antwort
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
Besonderer Dank geht an diese Übersetzer:
100%
Diese Übersetzer helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 21
Letzte 30 Tage: 63
Insgesamt: 3,748
