Zum Hauptinhalt wechseln
MacBook Pro 13" Retina Display Early 2015 Fan Replacement
Was du brauchst
  1. MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Lower Case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 2, Bild 1 von 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 3, Bild 1 von 2 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 3, Bild 2 von 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Battery Connector: Schritt 4, Bild 1 von 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 5, Bild 1 von 2 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 5, Bild 2 von 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 6, Bild 1 von 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Heat Sink: Schritt 7, Bild 1 von 3 MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Heat Sink: Schritt 7, Bild 2 von 3 MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Heat Sink: Schritt 7, Bild 3 von 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 8, Bild 1 von 2 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 8, Bild 2 von 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the following screws securing the heat sink to the logic board:
    • One 2.7 mm T5 screw (silver)
    • Four T5 screws (black)
  10. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 10, Bild 1 von 2 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 10, Bild 2 von 2
  11. MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Fan: Schritt 11, Bild 1 von 2 MacBook Pro 13" Retina Display Early 2015 Fan Replacement, Fan: Schritt 11, Bild 2 von 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 12, Bild 1 von 2 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 12, Bild 2 von 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 13, Bild 1 von 3 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 13, Bild 2 von 3 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 13, Bild 3 von 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 14, Bild 1 von 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 15, Bild 1 von 3 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 15, Bild 2 von 3 MacBook Pro 13" Retina Display Early 2015 Fan Replacement: Schritt 15, Bild 3 von 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
Abschluss
82 weitere Nutzer:innen haben diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
17 Kommentare
Very good instructions, just completed the fan replacement, no issues -
David Tyra - Antwort
Fantastic instructions, brilliant depictions for assistance. Thank you!
Ethan Tarquin - Antwort
I completed this guide and it was brilliant, so thank you Andrew Optimus Goldberg and your contributors! I have a question about the Macbook's heat post-installation of a new fan.
I replaced the fan last night, and put everything back together. Today, the new fan is responding well under activities that would previously make the fan extremely loud and cause intense heat to build up on the bottom right of the Macbook: so far so good.
However, it seems heat is now being distributed to the keys and directly below the screen, and I can even feel it underneath the trackpad, and this is from simply turning the Macbook on with no applications straining the CPU.
Is this something to worry about? Have I possibly made a mistake in my installation, or is this normal for an ordinary working fan?
Thanks for any help that may be given. Appreciated
Is the fan you replaced the original one with the exact same model? While im no expert on this stuff my guess would be that it distributes air differently. I hope it works out for you though.
Nikolay -
Just completed the fan replacement. Great clear instructions. No issues. Thank you so much.
Donald Kelly - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 83
Letzte 30 Tage: 424
Insgesamt: 90,737
