Zum Hauptinhalt wechseln
MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement
Was du brauchst
  1. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Lower Case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 2, Bild 1 von 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 3, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 3, Bild 2 von 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Battery Connector: Schritt 4, Bild 1 von 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 5, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 5, Bild 2 von 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 6, Bild 1 von 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Heat Sink: Schritt 7, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Heat Sink: Schritt 7, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Heat Sink: Schritt 7, Bild 3 von 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 8, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 8, Bild 2 von 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 9, Bild 1 von 1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 10, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 10, Bild 2 von 2
  11. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Fan: Schritt 11, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Fan: Schritt 11, Bild 2 von 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 12, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 12, Bild 2 von 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 13, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 13, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 13, Bild 3 von 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 14, Bild 1 von 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 15, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 15, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 15, Bild 3 von 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
  16. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, I/O Board: Schritt 16, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, I/O Board: Schritt 16, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, I/O Board: Schritt 16, Bild 3 von 3
    • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  17. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 17, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 17, Bild 2 von 2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket.
    • Remove the I/O board cable bracket.
  18. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 18, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 18, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 18, Bild 3 von 3
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the I/O board.
    • Be careful to only pry up on the cable connector, not on the socket itself or you risk damaging your I/O board.
    • Push the I/O board cable up to bend it out of the way.
  19. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 19, Bild 1 von 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 19, Bild 2 von 2
    • Use the tip of a spudger to push on either side of the I/O board connector to walk it out of its socket on the logic board.
  20. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 20, Bild 1 von 1
    • Remove the following screws securing the I/O board to the upper case:
    • One 3.5 mm T8 Torx standoff screw
    • One 3.5 mm T5 Torx screw
  21. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 21, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 21, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 21, Bild 3 von 3
    • Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case.
    • Remove the I/O board.
  22. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 22, Bild 1 von 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  23. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 23, Bild 1 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 23, Bild 2 von 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: Schritt 23, Bild 3 von 3
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Goldheart
465.647 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.732 Anleitungen geschrieben
Ein Kommentar
Thank you! My Macbook was not starting anymore and I saw that it will boot without the IO board. I got a new part, exchanged it and it is now working flawlessly.
winterchristian - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 62
Insgesamt: 33,346
