Einleitung
Diese Anleitung zeigt dir, wie du die defekte MagSafe Karte der Gleichspannungsversorgung (DC-In) austauschen kannst.
Entferne die folgenden zehn Schrauben, die den Boden des Gehäuses befestigen:
  • Entferne die folgenden zehn Schrauben, die den Boden des Gehäuses befestigen:
    • Zwei 2,3 mm Pentalobe Schrauben
    • Acht 3,0 Pentalobe Schrauben
For all the screws you use the P5 pentalobe screwdriver?
Carlos - Antwort
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - Antwort
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
the macbook in the picture is 2012. does it has the same structure as 2013?
Edison - Antwort
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - Antwort
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - Antwort
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - Antwort
Gehe mit deinen Fingern zwischen das obere und das untere Gehäuse.
  • Gehe mit deinen Fingern zwischen das obere und das untere Gehäuse.
  • Hebe die untere Gehäuseabdeckung vorsichtig vom Gerät ab.
Kommentar hinzufügen
Der Gehäuseboden ist durch zwei Steckverbindungen in dessen Mitte mit dem Gerät verbunden. Drücke während des Zusammenbauens vorsichtig auf die Mitte des Gehäusebodens, um die Steckverbindungen wiederherzustellen.
  • Der Gehäuseboden ist durch zwei Steckverbindungen in dessen Mitte mit dem Gerät verbunden.
  • Drücke während des Zusammenbauens vorsichtig auf die Mitte des Gehäusebodens, um die Steckverbindungen wiederherzustellen.
There are two screws that are shorter-they go to the back near the vent.
wrbandllm - Antwort
This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
addvariety - Antwort
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
Tommy Huang - Antwort
Falls nötig, entferne die Plastikabdeckung vom Batterieanschluss.
  • Falls nötig, entferne die Plastikabdeckung vom Batterieanschluss.
Trenne den Stecker der Batterie mit dem flachen Ende eines Spudgers von seinem Anschluss auf dem Logic Board. Gehe sicher, dass du nur den Konnektor und nicht den Sockel anhebst. Ansonsten besteht die Gefahr das Logic Board irreparabel zu beschdäigen.
  • Trenne den Stecker der Batterie mit dem flachen Ende eines Spudgers von seinem Anschluss auf dem Logic Board.
  • Gehe sicher, dass du nur den Konnektor und nicht den Sockel anhebst. Ansonsten besteht die Gefahr das Logic Board irreparabel zu beschdäigen.
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
jramsey21 - Antwort
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
salvatorebarbera -
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
andrehedegaard -
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Steve - Antwort
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
Vadim Gribanov -
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Ethan Tarquin - Antwort
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
Caleb Steinborn -
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Jonas Ehrs -
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
Parth Gudhka - Antwort
Biege den Stecker der Batterie etwas zur Seite, um während der Reparatur einen versehentlichen Kontakt mit dem Anschluss zu verhindern.
  • Biege den Stecker der Batterie etwas zur Seite, um während der Reparatur einen versehentlichen Kontakt mit dem Anschluss zu verhindern.
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
sebasgaes - Antwort
I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
LaymanLab - Antwort
That’s a great idea!
David Lilliebridge - Antwort
Fasse die schwarze Plastiklasche an und klappe den Sicherungsbügel am Stecker des Displaykabels hoch. Ziehe ihn dann gerade aus seinem Sockel auf dem Logic Board. Fasse die schwarze Plastiklasche an und klappe den Sicherungsbügel am Stecker des Displaykabels hoch. Ziehe ihn dann gerade aus seinem Sockel auf dem Logic Board. Fasse die schwarze Plastiklasche an und klappe den Sicherungsbügel am Stecker des Displaykabels hoch. Ziehe ihn dann gerade aus seinem Sockel auf dem Logic Board.
  • Fasse die schwarze Plastiklasche an und klappe den Sicherungsbügel am Stecker des Displaykabels hoch. Ziehe ihn dann gerade aus seinem Sockel auf dem Logic Board.
Ziehe den Stecker der Gleichstromversorgung gerade aus seinem Sockel auf dem Logic Board. Ziehe den Stecker der Gleichstromversorgung gerade aus seinem Sockel auf dem Logic Board.
  • Ziehe den Stecker der Gleichstromversorgung gerade aus seinem Sockel auf dem Logic Board.
Entferne die beiden 3,5 mm Torx T5 Schrauben, welche die MagSafe Karte am oberen Gehäuse befestigen.
  • Entferne die beiden 3,5 mm Torx T5 Schrauben, welche die MagSafe Karte am oberen Gehäuse befestigen.
  • Möglicherweise musst du das Displaykabel vorsichtig aus dem Weg schieben, um an die Schrauben zu gelangen.
Ziehe die MagSafe Karte am Kabel hoch und entferne sie aus dem oberen Gehäuse. Ziehe die MagSafe Karte am Kabel hoch und entferne sie aus dem oberen Gehäuse. Ziehe die MagSafe Karte am Kabel hoch und entferne sie aus dem oberen Gehäuse.
  • Ziehe die MagSafe Karte am Kabel hoch und entferne sie aus dem oberen Gehäuse.
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
11 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
Diese Übersetzer helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Sam Lionheart
Mitglied seit 18.10.2012
314.035 Reputation
1.632 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
117 Mitglieder
5.743 Anleitungen geschrieben
How can I know if the magsafe is not working ?
lpelaez - Antwort
Thanks for great tutorial!
Yep, what are the signs of bad dc-in board?
When I plug in the charger, LED on magsafe connector doesn't light up.
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
For some reason charging doesn't start, my battery has only 600 cycles on it.
Can you guys help?
P.S. I tried plugging other adapters thats working, same thing (
Olga Kolina - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 7
Letzte 7 Tage: 39
Letzte 30 Tage: 162
Insgesamt: 6,468
