Zum Hauptinhalt wechseln
MacBook Pro 13" Unibody Early 2011 Fan Replacement
Was du brauchst
Einführungsvideo
  1. MacBook Pro 13" Unibody Early 2011 Fan Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Fan Replacement: Schritt 2, Bild 1 von 2 MacBook Pro 13" Unibody Early 2011 Fan Replacement: Schritt 2, Bild 2 von 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Early 2011 Fan Replacement, Battery Connection: Schritt 3, Bild 1 von 2 MacBook Pro 13" Unibody Early 2011 Fan Replacement, Battery Connection: Schritt 3, Bild 2 von 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Early 2011 Fan Replacement: Schritt 4, Bild 1 von 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Early 2011 Fan Replacement, Fan: Schritt 5, Bild 1 von 3 MacBook Pro 13" Unibody Early 2011 Fan Replacement, Fan: Schritt 5, Bild 2 von 3 MacBook Pro 13" Unibody Early 2011 Fan Replacement, Fan: Schritt 5, Bild 3 von 3
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 13" Unibody Early 2011 Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. MacBook Pro 13" Unibody Early 2011 Fan Replacement: Schritt 7, Bild 1 von 1
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
Abschluss
To reassemble your device, follow these instructions in reverse order. (Always a good idea to first blow the dust out, wipe the inside cover, etc.)
134 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
Hi I did this and now my Mac won't turn on. When connecting the power supply the green light is on but absolutely nothing firing up. No fan no screen nada! HELP!
Mitesh - Antwort
Reopen the MacBook Pro and disconnect the battery cable, after 30 secs reconnect it.
This solution worked for me.
Nichi Ottolino -
This is a simple and easy repair if you follow the directions in the guide. The spudger is a good tool to have in your tool kit. Buy one if you don't have it.
Don Dine - Antwort
I broke the plastic fan socket of the logic board, is my computer ruined?
Steinar Hilmarsson - Antwort
No, But it will need to be repaired by an competent repair person. I charge $100 for this repair.
Troy Weakland -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 136
Insgesamt: 133,969
