Einleitung
Remove the lower case to access the internal components of your MacBook Pro.
Was du brauchst
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use your fingers to pry the lower case away from the body of the MacBook near the vent.
Remove the lower case.
60 weitere Nutzer:innen haben diese Anleitung absolviert.
