Einleitung
Hier wird der Austausch einer defekten AirPort/Bluetooth Karte gezeigt.
Entferne die folgenden zehn Schrauben:
  • Entferne die folgenden zehn Schrauben:
    • Drei 14,4 mm Kreuzschlitz #00 Schrauben
    • Drei 3,5 mm Kreuzschlitz #00 Schrauben
    • Vier 3,5 mm Kreuzschlitz #00 Ansatzschrauben
Does void the warranty?
jfondeur - Antwort
No, it does not void the warranty. More specifically: http://eshop.macsales.com/Search/display...
oakdragon12 - Antwort
How much weight can I save by removing the optical drive?
gunes314 - Antwort
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Also wondering how much weight I'd save by just removing. My drive is broken for ages, but I have not needed it in ages. The HD was already replaced by a cheap SSD (second best thing after upgrading to 8GB), so I'd appreciate losing some weight. I mean, the computer. Although I could lose some too... erm... well, anyway, I guess the lack of the DVD would not interfere with anything, right? Opinions?
Carlos Duarte do Nascimento - Antwort
Apple has meticulously balanced the MacBook's weight from left to right, and removing the optical drive may off-balance the Mac.
Seji the veggie -
What so you think that a removing the optical drive which weighs less than a AA battery will unbalance a MBP making it unusable? LOL!
Unless you use the MBP on a high wire (an even then I have my doubts) you'd never notice the weight difference.
pmhparis -
The issue is not one of weight but an issue with the systems cooling and an opening which objects could enter. For a few grams of weight I don’t think its worth it! A better solution would be to swap out the heaver HD for a much lighter SSD, and getting all of the performance benefits of the faster drive as well!
While you might not think it the optical drive also acts as a stiffener so there is less twist in the case. This is because of the size of the hole for the DVD/CD’s so taking it out weakens the case design.
Dan -
I'm thinking you'd probably be OK losing the DVD drive without a problem. Just make sure the optical drive cable is secured or you might hear it rattling in there from time-to-time.
John Adam Wickliffe - Antwort
Hey guys,
this website is amazing. I read it to guide me on fixing my mac book pro, but on the video, the girl gives a wrong information.. She says that is not possible replace just the keyboard... But I managed to replace only my keyboard. It is boring because I have to remove approximately 70 screws but it is possible. Thanks a lot! You guys helped me save about US$300 thats because in Brazil some technicians would charge me with that amount!
I posted some pictures on your facebook page..
renatumb - Antwort
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - Antwort
Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
kschmesk - Antwort
I tried the PH #00 for the 10 screws that hold the bottom case and it's too big, instead PH #000 works perfectly. Are you sure this screws are #00?
Alex - Antwort
The likely problem with your wifi is not the card but the antenna leads that go into the plastic clutch
. Ifixit don't have a guide to change this as it it includes the isight camera so the screen has to be disassembled which is fairly hard
I got round it by using the camera cable from the old set and cutting off the new one
brian whittle - Antwort
Hello MacWorld,
Just want to say that this site is a great resource for repairing or upgrading your Mac. I had a bad SATA cable in my MacBook Pro and after ordering a new one from the "IFIXIT" site I received the cable within two days, replaced it and was up and running again in no time. Thanks IFIXIT for you help!
wer 10/5/15
tayseer999 - Antwort
I have found that my MacBook Pro 13 Late 2011 has five shouldered screws and not four. I am not sure exactly where it goes but I have put it in the top left corner of the picture as it is the odd one out.
GotMac - Antwort
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - Antwort
on my device the #00 screwdriver was a bit too small. a #0 was the perfect one
Maximilian Klotz - Antwort
I found with mine that the shouldered and un-shouldered screws were reversed (the three un-shouldered screws going where the orange colour indicates). Also, I found that the front four screws went in at an angle.
gilded yak - Antwort
Are you sure the short screws are different? The set sold here just says “Seven 3 mm Phillips #00 screws.”
Jack - Antwort
I have the same question. What is the difference between shouldered and not? So hard to see any difference…
Michael Wilkens -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - Antwort
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
I used 3 eggcups to hold the screws ;>) They are very fiddly and easy to drop on floor so keep the MacBook away from the edge of the surface you are using to avoid accidentally dropping a screw off the edge of a table, etc.
Stephen Smith - Antwort
A screw does not come out, how can I get it out? Many thanks in advance for your help
Wilder Torres - Antwort
Since you’ll be removing many screws it’s best to plan ahead. I found it especially helpful to have a small plastic tray with about a dozen separate compartments to hold screws. As I removed screws I kept them in one compartment for each item removed. For example: The lower case removal involves the removal of ten screws. I kept them all in the first tray compartment and set the lid aside. Also, I put a post-it note identifying this compartment as “Lower case” and noted that the top right-most screws were the long ones. I continued with this methodology as a removed the next item, and the next, etc. Disassembly notes included for each compartment. This helped SIGNIFICANTLY as I was able to reassemble the Macbook easily by simply going from one compartment to the next (in reverse order). This guide is rated “Difficult” which it really isn’t when you plan ahead in this way. It saves time in the long run.
airshack - Antwort
when putting the macbook pro back together, the middle screw on the right side (if the computer is upside down and you have the hinge furthest away from you) requires a bracket that was not included with my new upper case. i had to remove it from my old case and transfer it over - if you don’t do this, that screw will have nothing to attach to.
this was one of the many additional parts i needed to transfer from my old case to the new one that aren’t mentioned in this guide…i’m adding comments on each step to try to help others…i wish i had thought to take pictures.
Matt - Antwort
It seems to me the yellow and orange screws are the same
Luca Giancarli - Antwort
If you look closely, the four front screws (with the yellow circles) have a short unthreaded section under the head. The orange keyed screws are threaded all the way up.
Raymond Ives -
The screws used on all Retina models, as well as about everything Apple has made since the iPhone 4, uses “PENTALOBULAR” not Phillips screws. These look like a TORX driver, but it has 5 concave sides. I believe the size you want is a P4 or T4. (1.2mm).
Don Cely - Antwort
Two screw types:
______________________________
Shouldered Unshouldered
xxxxxxx……….xxxxxxx
..xxxxx……..….…….x…….
…..x……..…...……….x…….
…..x…………....……..x…….
El Crashitan - Antwort
If you are following this guide to upgrade to a better drive and want to keep your system and data intact I highly recommend first following the guide to Clone an Existing Drive using the recommended free SuperDuper!. That process was a breeze and gives you confidence that the new drive will come up looking exactly the way it did when you started.
Patrick Langvardt - Antwort
Löse mit den Fingern in der Nähe vom Ventilator die Gehäuse-Unterseite vom Hauptteil des Gehäuses.
  • Löse mit den Fingern in der Nähe vom Ventilator die Gehäuse-Unterseite vom Hauptteil des Gehäuses.
  • Entferne die Gehäuse-Unterseite.
If the black vent window that is attached to the back cover becomes loose what kind of glue should be used to attach it again, thermal paste or super glue?
Thanks for your help.
Mikell - Antwort
bonjour cette truc ça marche au mac Brook pro Retina ou pas?
Shi Feng - Antwort
Bonjour, alors cela va dépendre du modèle de MacBook Pro Retina concerné. Par exemple, si vous avez un 13 pouces, allez consulter cette page MacBook Pro 13" Retina Display Repair et sélectionnez-y votre modèle. Les Retina 15 pouces se trouvent ici MacBook Pro 15" Retina Display Repair. Sinon cet outil https://fr.ifixit.com/info/ID-your-Mac (pour l’instant seulement disponible en anglais) vous aide à identifier quel modèle vous avez et vous redirige vers la page de votre appareil, où vous trouverez le tutoriel correspondant à votre Retina. Bonne réparation !
Claire Rapp -
Merhaba, trackpad değişimi ve ayarlaması için tornavidaya ihtiyacım var, bu konuda yardımcı olabilir misiniz acaba? Ne tür bir tornavidaya ihtiyacım var ve nereden bulabilirim acaba?
Volkan Ogul - Antwort
  • Löse mit der Kante eines Spudgers den Akkuanschluss nach oben, weg vom Sockel auf dem Logic Board.
  • Es ist hilfreich, beide kurzen Seiten des Anschlusses gleichzeitig nach oben zu hebeln. Sei vorsichtig mit den Ecken des Anschlusses, da diese sehr leicht abbrechen können.
Is this step of removing the battery connector required?
manodh - Antwort
yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
khull -
Sooo the track pad is under the battery...you kind of have to remove it to get to the track pad.
stiknrudder -
This step is not really required. Apple does not recommend it.
Steven Layton - Antwort
My Battery does not get recognized after i disconnected it, screw this site!
Diego Hernandes -
Did you properly ground yourself to the case before putting the spudger to the connector/logic board? Did you use a spudger or something else that is non conductive...or did you use a flat blade metal screw driver instead and compound your error by not grounding yourself before touching the logic board? All kinds of variables here but the bottom line is iFixit provided you a guide to fix your computer. Lots of others have followed this guide without trouble. Your battery issues are not their fault. They did say this guide was moderate difficulty...maybe it's just a little beyond your skill level. We should all know our limits!
stiknrudder -
Rather than be careful of the corners of the connector i would say don't use the spudger anywhere near the corners. While the corner looks like the obvious place to begin to pry it up from, it will break. Levering from the sides as the instructions suggest works well.
ausmkv - Antwort
wonder why apple does not recommend it?!
Peter - Antwort
I would recommend it, one careless short and the whole board is dead......
John - Antwort
simply remove the battery rather than disconnecting the cable
toiu - Antwort
What do you mean by "remove the battery"?
Anrothan -
Don't know what the deal is with the battery, but this IS a necessary step to keep from frying the logic Board if you accidentally touch something and short it out. I did this step every time during my troubleshooting and The battery was ALWAYS recognized by the system the next time I turned the MBP on. So be safe and don't fry your logic board in the process...
fasthans - Antwort
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
aekinaka - Antwort
Installed/upgraded 4gb RAM to the system maximum 16gb and installed a 500 gb SSD today....DID NOT disconnect the battery cable....no issues at all when I powered back up. Then did a clean install of OSX Yosemite....next I used a time machine backup to put all my stuff back on the new HD. From start to finish it took about 4 hours. Macbook boots up right at 16 seconds now.
MacProUser - Antwort
Easiest to use two spudgers, one on each short end, I found.
Simon Mundy - Antwort
I took off th Airport /Bluetooth connectors but the number J3 connector is broken and so where can i buy J3 connecter for the Airport/bluetooth board
Zeerachen - Antwort
Its a lot easier and safer (corner wise) to pry it using the flat side of the black spudger directly in front of the connector (don't go/use the corners) very easily you will be able to pry it further by inserting the spudger into a better and thicker plastic section of the connector
Ed Oliver - Antwort
DON'T remove the Battery Cable, you risk the battery NOT being recognised when you start the Mac up again, or breaking it!! More to the point, APPLE DOES NOT RECOMMEND THIS, so don't do it! I Installed 2x 8GB ( 16Gb total) of Crucial Mac RAM at 1333Mhz for my Late 2011 MacBook Pro, and it works beautifully, fully recognised and working well. I followed these instructions, but as Apple didnt recommend disconnecting the battery, I skipped this step, and as well as taking less time, nothing was damaged or broken, and everything works perfectly!!! Just make sure that you DISCHARGE ALL STATIC ELECTRICITY FROM YOUR HANDS, by touching a metal surface in the Mac. Apple recommends the edge of the Optical Disk Drive ( Big silver thing ) before touching any parts. Also, Take care removing the RAM out of its packet, DO NOT touch the Gold connectors, and hold the RAM by the edges. Finally, be PATIENT, GENTLE and it should all go perfectly. I managed it first time, with no technical ability, so follow my advice. Good luck!
Bradley Marks - Antwort
Followed the tuto Step by step. Disconnected the battery (quite easily).
No problem when I lit the Mac on again. Battery's here, date's right.
nichoferr - Antwort
Switch off your Mac and continue without disconnecting the battery. Don't know how it will switch on by itself.
Mfernandez - Antwort
This comment made me think that disconnecting the battery was no point at all, because really - how would the computer be able to switch on by it self. So... I had my mac flipped around and was fiddling with the last part of the guide when I all of a sudden hear the start up sound! Don't know how and why it did. I turned it around with it guts open and guts hanging out. Screen was on. I forced it to shut down by keeping the power button down. Turned it back and first thing removed the battery cord.
Luckily the computer started up just like normal. But hearing that sound was just too scary.
BTW I had been cautious to de static myself multiple times.
wassberg -
Definitely do this step. It's an easy disconnect anyway and also easy to reconnect later.
I removed the battery cable for the repair. When I plugged in the MagSafe adapter after the repair, the Mac turned on automatically without pressing the power button and I was a bit worried, but after a restart everything worked fine again. I did have to reset date and time in Preferences. The battery was recognized OK.
Raymond Rinaldi - Antwort
Okey, I skipped this battery disconnection part. Did not do anything like this before in my life, changing the cable was super easy!
Marijke de Vries - Antwort
The official Apple guide to replacing the RAM says nothing about disconnecting the battery but it does recommend touching metal inside to discharge static. https://support.apple.com/en-us/HT201165
B T - Antwort
I always do this when working on MacBooks (over ten years) and it never caused an issue. Don’t worry about this step as removal of the battery connector is simple. This particular connector is pretty much goof-proof as it won’t break. I’m fairly aggressive and just pop it off whenever I’m working on the Macbook Pro.
airshack - Antwort
Hello!
Do I really need to use a spudger tool? Can’t I just use like two plectrums for guitar? xD
Myzcio - Antwort
  • Biege das Akkukabel vorsichtig weg vom Sockel des Logic Boards, damit es sich nicht aus Versehen beim Arbeiten wieder verbindet.
What are the changes of it broke when i bend it?, after i disconect it does not work anymore
Diego Hernandes - Antwort
The guide worked perfectly, as it has in the past (our family has three Mid-2012 Macbook Pros that have been separately upgraded with RAM and SSD).
The PH00 screwdriver fit perfectly.
One note on getting the screws to seat easily and thread perfectly...always turn them gently a couple turns to the left (CCW or Anti-Clockwise) until you hear a small click. That's where the threads will grab. Works with any screw, but when threads are fine, this will help ensure that the screw is at the correct angle and will grab and seat perfectly.
Great guides. Thanks!
timgunkel - Antwort
Got RAM in but only one slot is working and now I can't remove! The RAM won't pop up like before and tabs don't seem to do anything. Please advise.
Sal Ergrapes - Antwort
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
Followed the advice and right as I was installing the replacement fan , the socket broke right off the motherboard.
Ian Thal - Antwort
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
lelandjordon - Antwort
does the battery connection need to be removed? I only ask as other videos etc have not shown this step.
Darren Rose - Antwort
  • Hebe den Verbinder zum Airport/Bluetooth Kabel mit dem flachen Ende des Spudgers aus seinem Sockel auf dem Logic Board.
N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
Greg - Antwort
  • Ziehe vorsichtig das Kamerakabel aus seinem Sockel auf dem Logic Board.
  • Ziehe das Kabel parallel zur Oberfläche des Logic Boards. Wenn du es nach oben ziehst, kannst du das Logic Board oder das Kabel selbst beschädigen.
I ripped the camera cable where can I buy a new one
fadybitar2000 - Antwort
Be very careful at step 6!
I had the same problem with the model "Late 2011" and I doubt to step 6 because the camera cabel connector was plugged very tight in the board-socket. So I cannot believe it is so easy to unplug the connector.
I bought a new camera cable on eBay.
Tomasz Borkowski - Antwort
Be extremely careful on step 6 with late 2011 model unibody macbooks! The cable is connected very tightly to the board and has a great chance of ripping if you just pull the cable.
Tim Rauls - Antwort
I ripped the camrea cable socket on the logic board.
Pedram Fattahi - Antwort
Walk the cable out with a spudger!!! The Retina 2012 guide has this and this was so easy using the tool.
Robert Le Monds - Antwort
  • Schiebe das Flachbandkabel von Airport/Bluetooth vorsichtig aus dem Weg und löse das Kamerakabel von der Klebeverbindung mit der es am Subwoofer und der Halteklammer angebracht ist.
  • Fädle das Kamerakabel aus dem Bügel in der Halteklammer von AirPort/Bluetooth.
What adhesive is suitable for reattaching the foam tape and wires that were removed from their normal routing?
David Warshowsky - Antwort
I want to know that too!
Alberto Harres Rocha -
Take a few phone close-ups of this corner of your system prior to disassembly. Extra photos really help during reassembly.
airshack - Antwort
I didn’t use any extra adhesive here during reassembly. The camera cable fits snuggly between the subwoofer module and the DVD drive. Apple’s adhesive here is really just overkill.
airshack - Antwort
  • Hebele den Antennenverbinder, der am nächsten zum Logic Board ist, aus seinem Sockel auf der Airport/Bluetooth Platine hoch.
  • Fädle das Antennenkabel aus dem Bügel in der Halteklammer von AirPort/Bluetooth.
Can someone explain me what this "antenna cable" is for? I changed my Topcase and this antenna did break during the procedure =(.
The problem is i can't find this cable anywhere to buy and i don't even know his function. WIFI and Bluetooth are working just fine.
Can someone please help me?
kadiroeztel - Antwort
Same here, I was removing the display and once i put it back on the three little antenna cables fall off. Any idea how to replace it or find it?
Hector Torres -
Those are the WiFi antennae..
auadix -
When I was repairing the hinge of my laptop two of the antenna cable connectors came off the ends of the antenna wires. Can someone confirm what these are called and the size so I can source replacements? I believe they may be called ’Micro RF Coax Connector’ but I am not sure what size I need. For the record the wifi is actually still working but may be a bit slower than normal. Thanks for your help.
Alan Holt - Antwort
  • Löse mit der eben beschriebenen Methode die restlichen drei Antennenverbinder.
  • Fädle ihre Kabel aus den Ausschnitten in der Halteklammer von AirPort /Bluetooth
What are these? Like in order? I broke the middle one and am trying to find a replacement. The mac actually functions quite normally, currently using it to type this ahaha, anyways, only difference I've noticed is that the speaker sounds a bit weird/off. Internet is fine, display is fine, everything is fine at the moment besides the speaker. And in case you're wondering how exactly broken it is, its not connected to begin with since it ripped ahahaa...
Lupita Felix - Antwort
I found re-attaching these antennae connectors the trickiest bit by far as they appear very delicate and seating them correctly was fiddly. In the end lighting them from the side with a small torch helped to check their position before gently pushing them down. The first one made a clicking sound as it connected, the other two went on silently. MBP wifi working perfectly now. I’m fairly sure that was at least £100 of labour had I taken it in for repair so thanks ifixit for saving me money and for the warm glow of accomplishment!
Andrew - Antwort
  • Entferne folgende fünf Kreuzschlitzschrauben:
    • Zwei 10,3 mm Schrauben
    • Zwei 3,1 mm Schrauben
    • Eine 5mm Schraube
The two screws marked in orange are not present in my early 2011 macbook pro
bhavishya tyagi - Antwort
Should be worth noting that the black tape/wire grommet on the right red screw is flimsy. When overtightened, it can tear.
Brad Stossel - Antwort
  • Hebe die Airport /Bluetooth-Einheit und den Subwoofer in der Seitenmitte beim optischen Laufwerk hoch bis sie sich voneinander lösen.
Kommentar hinzufügen
  • Entferne die AirPort/Bluetooth-Einheit. Achte dabei auf den empfindlichen Antennenkontakt in der Nähe der Gehäuseecke.
  • Löse das Stück EMI Band ab, welches auf den Stecker des AirPort/Bluetooth Kabels geklebt ist.
  • Hebe den Stecker am AirPort/Bluetooth Kabel mit der Spudgerspitze aus seinem Sockel auf der AirPort/Bluetooth Karte.
  • Entferne das AirPort/Bluetooth Kabel.
  • Löse weiterhin das EMI Band von der Unterseite der Halterung der AirPort/Bluetooth Karte ab und entferne es von der Einheit.
  • Entferne die drei 3 mm Kreuzschlitzschrauben, welche die AirPort/Bluetooth Karte an ihrer Halterung befestigen.
  • Entferne die AirPort/Bluetooth Karte aus ihrer Halterung.
  • Achte darauf, dass du nicht das rosafarbene Thermopad beschädigst, welches auf der Halterung angeklebt ist.
I did the whole thing and my new AirPort isnt working.. i checked twice the cables and nothing yet.. does anyone know if i need to download something to make the mac recognize my AirPort? - the bluetooth is working in both boards (the old one and the new one).. any clues to help me out here?
paulofjunior - Antwort
Any idea what was wrong with your computer. I'm in the exact same situation.
goreds6 -
I accidentally pried the soldered connector off the board (the j3 bt connector) as I have seen this connector is only two/ three channel. Is it an option to try to solder back the connection? Thanks for all of your help Ifixit!!
skogliruben2 - Antwort
I did the same thing as skogliruben2. the J3 bt connect popped right off with the antenna cable when I tried to pry it off. I'd also like to know if I can try soldering it on. I really can't even disconnect the little connecter from the cable socket now. What does this antenna do? Thanks for your help!
maryetna - Antwort
Awesome guide! I just replaced the AirPort/Bluetooth board in my 6 year old mid-2012 MacBook Pro 13-inch and extended it’s life.
I also replaced the battery, fan, and installed a SSD so this MacBook Pro will hopefully serve me well for another 6 years ;-) Thanks for the awesome guide.
Abe Collins - Antwort
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
23 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
Diese Übersetzer helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Phillip Takahashi
Mitglied seit 22.08.2011
73.797 Reputation
85 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 7
Letzte 7 Tage: 44
Letzte 30 Tage: 167
Insgesamt: 22,071
