Einleitung
This guide has been updated by iFixit staff! Read the new, official guide here.
Was du brauchst
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Red Seven 3 mm Phillips screws.
Orange Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Remove the following tri-wing screws securing the battery to the upper case:
Red One 5.5 mm tri-wing screw
Orange One 13.5 mm tri-wing screw.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
