Einleitung
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Was du brauchst
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
Two 10 mm T6 Torx screws on either side of the RAM slot.
Four 14.5 mm Phillips screws along the hinge.
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Disconnect the three antenna cables attached to the Airport Extreme card.
Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the inverter cable from the logic board by placing a spudger beneath the cable and lifting up.
Remove the silver T6 Torx securing the ground loop in the display data cable to the casing.
Support the display with one hand while removing the following 3 screws:
Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
Grasp the display assembly on both sides and lift it up and out of the computer.
26 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Real easy to follow. Great and simple instructions.
