Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Provides power to the machine and includes all ports on the left side of the machine.
  1. Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. Remove the three identical Phillips screws from the memory door.
    • Remove the three identical Phillips screws from the memory door.
  3. Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. Remove the following 6 screws:
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. Remove the four 3.2 mm Phillips screws on the port side of the computer.
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
    • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
  12. Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
    • Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
  13. Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  14. Remove the following 3 screws:
    • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
  15. Lift the left fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    • Lift the left fan up and carefully peel up the tape securing the fan to the heat sink as you go.
  16. Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  17. Disconnect the three antenna cables attached to the Airport Extreme card.
    • Disconnect the three antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  18. Remove the single black T6 Torx screw located just above the Airport Extreme card.
    • Remove the single black T6 Torx screw located just above the Airport Extreme card.
  19. Lift the Airport Extreme card up and slide it out of its connector.
    • Lift the Airport Extreme card up and slide it out of its connector.
  20. Deroute the Airport antenna cables from their channel in the left speaker.
    • Deroute the Airport antenna cables from their channel in the left speaker.
  21. Peel up the orange hard drive cable from above the ExpressCard cage.
    • Peel up the orange hard drive cable from above the ExpressCard cage.
  22. Disconnect the speaker cable from the corner of the left I/O board.
    • Disconnect the speaker cable from the corner of the left I/O board.
  23. Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
    • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
  24. Disconnect the large gray and black power cable from the left I/O board.
    • Disconnect the large gray and black power cable from the left I/O board.
  25. Remove the following 5 screws/standoffs:
    • Remove the following 5 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
  26. Lift up the right side of the left I/O board and slide it out of the computer.
    • Lift up the right side of the left I/O board and slide it out of the computer.
  27. Remove the four Phillips screws securing the ExpressCard cage to the left I/O board.
    • Remove the four Phillips screws securing the ExpressCard cage to the left I/O board.
  28. Lift the left I/O board off the ExpressCard cage.
    • Lift the left I/O board off the ExpressCard cage.
  29. Disconnect the short left I/O board cable.
    • Disconnect the short left I/O board cable.
    • Left I/O board remains.
Abschluss
26 weitere Nutzer haben diese Anleitung absolviert.
iRobot
1 Reputation
643 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 8
Insgesamt: 26,933
