Einleitung
Removing a few screws will remove this part and allow access to your RAM.
Was du brauchst
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
