Einleitung
¡Todo lo que necesitas para quitar la batería son tus dedos!
Was du brauchst
Usa tus dedos para empujar ambas lengüetas de liberación de la batería lejos de la batería, y levanta la batería de la computadora.
Para volver a montar tu dispositivo, sigue estas instrucciones en orden inverso.
80 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
Help! After installing new battery, one of the tabs does not close totally, leaving a bit or orange showing, and mouse pad is hardly operational. Cannot seem to get it to install completely. Put old battery back in to double check and its fine. Tried new battery 3 times to no avail!! Any tips?? Thank you!
Mmm, I think in two options:
1. The new battery has some imperfections and don´t met the official dimensions.
2. If the new battery is used, had an overheat and that caused a variation in its dimensions.
Sorry if I can´t help you more
This has to be the easiest iFixit tutorial ever! Haha
