Einleitung
Um den Akku zu entfernen brauchst du lediglich deine Finger!
Was du brauchst
Ziehe mit deinen Fingern beide Laschen vom Akku weg und hebe den Akku aus dem Computer heraus.
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
131 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
Hello,
I have found a really important mistype, on this page.
I assume, that on the picture, those tools are not thumbs but the "Introduction" says so!!! Those are "finger" tools.
It can mislead persons like me also, with my 25 years old of highly educated professional tool user experience.
Please correct the tools down below.
With the thumb tool, i was unable unattach the battery from the case.
BR
Indeed, executing the detachment process of the battery using "thumbs" is a highly risky operation only to be performed by well-trained thumb specialists. The use of other "fingers" is much more common, as it might induce fairly less risk of severe injuries or death. Also, "Fingers" have a sweet little picture illustrating the right tool to use. I changed the guide accordingly.
Thank you so much gentleman for your help.
I appreciate the professional answer and the correction.
From now on i can sleep well at nights.
