Zum Hauptinhalt wechseln
Einleitung
How to remove the hard drive, along with its cable and bracket from your computer.
  1. Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. Remove the three identical Phillips screws from the memory door.
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
  3. Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. Remove the two Phillips screws in the battery compartment near the latch.
    • Remove the two Phillips screws in the battery compartment near the latch.
  5. Remove the following 6 screws:
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. Remove the four Phillips screws on the port side of the computer.
    • Remove the four Phillips screws on the port side of the computer.
  7. Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
  10. Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. Disconnect the orange hard drive ribbon cable from the logic board.
    • Disconnect the orange hard drive ribbon cable from the logic board.
  12. Use a spudger to carefully loosen the adhesive securing the sleep light and IR sensor connectors to the top of the hard drive.
    • Use a spudger to carefully loosen the adhesive securing the sleep light and IR sensor connectors to the top of the hard drive.
  13. Remove the two silver Phillips screws securing the hard drive retaining bracket to the lower case.
    • Remove the two silver Phillips screws securing the hard drive retaining bracket to the lower case.
    • In some machines these screws may have T6 Torx heads.
  14. Slide the Bluetooth board out of its slot next to the hard drive. The Bluetooth board is still connected to the orange hard drive cable, so don't try to remove it entirely from the computer.
    • Slide the Bluetooth board out of its slot next to the hard drive. The Bluetooth board is still connected to the orange hard drive cable, so don't try to remove it entirely from the computer.
  15. Lift the hard drive up with one hand and use your other hand to remove the retaining bracket from the side of the hard drive.
    • Lift the hard drive up with one hand and use your other hand to remove the retaining bracket from the side of the hard drive.
  16. Disconnect the orange hard drive cable.
    • Disconnect the orange hard drive cable.
    • After installing the new hard drive, make sure the vent hole (on top) is not covered by the orange ribbon cable.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
iRobot
1 Reputation
647 Anleitungen geschrieben
Ein Kommentar
I love everyone's different approaches. I used a piece of paper with written descriptions of screw locations. I put a strip of double-sided tape next to each description and stuck the screws to them. The paper got moved all over my office before I finished the project, and the screws stayed in place.
modulus204 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 15,273
