Zum Hauptinhalt wechseln
Einleitung
Input, Output, Sideput. Whatever kind of puting you will be doing, a faulty I/O board cable is going to severely limit the functionality of your MacBook Pro. This guide will show you how to replace it.
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 2, Bild 1 von 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 2, Bild 2 von 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 3, Bild 1 von 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 3, Bild 2 von 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 3, Bild 3 von 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: Schritt 4, Bild 1 von 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 5, Bild 1 von 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 5, Bild 2 von 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 5, Bild 3 von 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): Schritt 6, Bild 1 von 1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 7, Bild 1 von 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 7, Bild 2 von 2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 8, Bild 1 von 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 8, Bild 2 von 2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: Schritt 9, Bild 1 von 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
iFixit Mitglied von iFixit
Community
148 Mitglieder
15.460 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 13
Letzten 30 Tage: 82
Insgesamt: 6,860
