Zum Hauptinhalt wechseln
MacBook Pro 15" Touch Bar 2017 Logic Board tauschen
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzubauen, folge dieser Anleitung in umgekehrter Reihenfolge.
23 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
Arty
32.976 Reputation
110 Anleitungen geschrieben
12 Kommentare zur Anleitung
The video is very good although there are a few things that in my mind could be a lot better, first is the availability to view the removal of the Mainboard in Full-screen mode to make it easier to see what is being used and the detail of the board as well. The other is that I use a Fix-it organisation tray for all the screws and bits that come out of the device I’m stripping down, os that I can put the bits back into the device in the reverse order they came out, but in this video that doesn’t happen and the screws start to go back in totally differently, so please if you're going to do this then put the items back in the order they were taken out, and point things like different size screws etc, otherwise, this was helpful, if a little confusing.
Roberto Enrieu - Antwort Teilen
Thank you, I’ll use your recommendations in future instructions.
Arty - Antwort Teilen
What happened to the very concise step by step produced by iFixit for the 2016, 15” MBP touch Bar.? Why was it taken down?? This new video. while informative doesn’t compare to the multi step picture guide that was removed. Can someone answer this?
Macrepair SF - Antwort Teilen
Not ifixit guide but this guys videos are great https://www.youtube.com/watch?v=_mwHGidM...
Peter Newman - Antwort Teilen
what is max temp used for removing efi chip
jay - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 99
Letzte 30 Tage: 437
Insgesamt: 48,640
