Einleitung
How to replace the airport card in a MacBook Pro 15" Unibody late 2008/early 2009.
Ersatzteile
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
Deroute the camera data cable from the channel in the optical drive.
Remove the two Phillips screws securing the camera cable bracket to the upper case.
Seperate the camera cable bracket from the camera cable and remove it from the computer.
Grab the plastic pull tab secured to the LVDS cable lock and rotate it toward the DC-in side of the computer.
Pull the LVDS connector straight away from its socket.
Remove the 7 mm Phillips screw from the LVDS cable bracket.
Lift the LVDS cable bracket out of the upper case.
Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (four screws total).
Open your MacBook Pro so the display is perpendicular to the upper case.
Place your opened MacBook Pro on a table as pictured.
While holding the display and upper case together with your other hand, remove the 6 mm Torx screw from the lower display bracket.
Remove the last remaining 6 mm Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
Lift the clutch cover up off the front bezel and set it aside.
Remove the two Phillips screws holding down the airport board.
Carefully unplug the two antenna cables and the airport cable.
38 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
It was easier than expected, except for putting the plastic hinge cover back on properly, the plastic feels weak, but it’s stronger than it feels!
First time I took apart the screen from the body it took me 20mins being careful, now I can do it in less than 6mins! I’ve it a few times now!
