Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Disconnect the camera cable by pulling the male end straight away from its socket.
Use a spudger to pry the optical drive connector straight up off the logic board.
Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case.
Lift the camera cable bracket out from the upper case.
Remove the following three Phillips screws securing the optical drive to the upper case:
One 3.5 mm Phillips screw.
Two 2.5 mm Phillips screws.
Fast fertig!
Abschluss
