Zum Hauptinhalt wechseln
MacBook Pro 15" Unibody Late 2011 Right Fan Replacement
Was du brauchst
  1. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement: Schritt 2, Bild 1 von 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement, Battery Connector: Schritt 3, Bild 1 von 2 MacBook Pro 15" Unibody Late 2011 Right Fan Replacement, Battery Connector: Schritt 3, Bild 2 von 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement: Schritt 4, Bild 1 von 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement, Right Fan: Schritt 5, Bild 1 von 3 MacBook Pro 15" Unibody Late 2011 Right Fan Replacement, Right Fan: Schritt 5, Bild 2 von 3 MacBook Pro 15" Unibody Late 2011 Right Fan Replacement, Right Fan: Schritt 5, Bild 3 von 3
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
  7. MacBook Pro 15" Unibody Late 2011 Right Fan Replacement: Schritt 7, Bild 1 von 1
    • Lift the right fan out of the upper case.
Abschluss
27 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I continue to repair my 10 year MBP and hope to keep it running as long as possible. Thanks Miroslav, all iFixit contributors, and iFixit!
Barb - Antwort
Struggled with replacement fan electrical connection back to board; until I (stupidly) realized they needed a twist (upside down). Thanks!
Greg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 8,409
