Einleitung
このガイドを使って、消耗したバッテリーを交換してください。バッテリーが膨張している場合は、適切な方法で処理をしてください。
Was du brauchst
ナイロンスパッジャーの先端を使って、「警告:バッテリーを取り外さないでください」と記載のあるステッカーの先端を折曲げ、下に隠れている3本目のペンタローブネジを外して下さい。
バッテリーケーブルコネクターの接続を切る際には、バッテリーを十分に傾けて下に隙間を作ってください。
バッテリーケーブルのコネクターをメイン基板のソケットから手前に引いて接続を切り、バッテリーを上部ケースから取り外します。
デバイスを再組み立てする際はこれらの手順を逆の順番に従って作業を進めてください。
290 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
18 Kommentare
Ordered the battery from iFixit, forgot to order the Pentalobe screwdriver. Nevermind, if you only do that stuff once (as I expect after 6 years with one battery) - don't spend the money on special equipment that cannot be used for anything else :)
Opening the macbook is easy (I have done that before to exchange the superdrive with a larger harddisk and the original HD with an SSD drive, and a couple of times to clean the fans), but the 3 screws on the battery are a pain.
What did the job for me: an old mini-flathead-screwdriver (approx. 2mm? - just slightly larger than the pentalobe) and a file. As none of my other screwdrivers would work with the ....pentalobes, i filed down the flathead (-)screwdriver so that it could get hold in 2 of the lobes - which did let me open and close these screws without a problem. My screws were not closed very tight though - if they are there is probably no way around the right tool.
Hello , I just replaced the battery on my macbook pro 15 inch 2009. Original battery was dead, would not even start without being plugged in.
I replaced the battery myself with one from amazon. Lizone is the brand. Laptop powers on now without being plugged in but after I enter my password it turns off, right after the login screen. Doesnt matter if its plugged in or not. I can access the login screen and thats it. When I removed the battery the laptop starts normal and I can get past the login screen and into el capitan.
I reseted SMC and PRAM multiple times. Is it a faulty battery ? What can I try?
