Einleitung
Replace a faulty fan to keep temperatures down.
Ersatzteile
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the flat end of a spudger to disconnect the left fan connector from the logic board.
Remove three T6 Torx screws securing the left fan to the logic board.
Lift the left fan out of the upper case.
65 weitere Nutzer haben diese Anleitung absolviert.
