Einleitung
Replace a faulty fan to keep temperatures down.
Was du brauchst
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the flat end of a spudger to disconnect the left fan connector from the logic board.
Remove three T6 Torx screws securing the left fan to the logic board.
Lift the left fan out of the upper case.
71 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Great guide, easy work to do! If I can do this, anyone can. If I can do this, someone who does not exist almost can. Not quite! But almost. I was happy to get that squalling and howling old fan out of my MacBook Pro, and thereby to end the squalling I got from my family over the noise it made. Like the old one, the new fan works great, but it is new, and quiet, and I am thankful. Happy customer.
