Zum Hauptinhalt wechseln
MacBook Pro 17" Unibody Bluetooth Board Replacement
Was du brauchst
  1. MacBook Pro 17" Unibody Bluetooth Board Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Bluetooth Board Replacement: Schritt 2, Bild 1 von 2 MacBook Pro 17" Unibody Bluetooth Board Replacement: Schritt 2, Bild 2 von 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Bluetooth Board Replacement, Battery: Schritt 3, Bild 1 von 3 MacBook Pro 17" Unibody Bluetooth Board Replacement, Battery: Schritt 3, Bild 2 von 3 MacBook Pro 17" Unibody Bluetooth Board Replacement, Battery: Schritt 3, Bild 3 von 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Bluetooth Board Replacement, Bluetooth Board: Schritt 4, Bild 1 von 1
    • Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
    • Pull the cable parallel to the face of the optical drive.
  5. MacBook Pro 17" Unibody Bluetooth Board Replacement: Schritt 5, Bild 1 von 1
    • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
  6. MacBook Pro 17" Unibody Bluetooth Board Replacement: Schritt 6, Bild 1 von 1
    • Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
  7. MacBook Pro 17" Unibody Bluetooth Board Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 2.2 mm Phillips screws securing the Bluetooth housing to the side of the optical drive.
  8. MacBook Pro 17" Unibody Bluetooth Board Replacement: Schritt 8, Bild 1 von 1
    • De-route the camera cable from its slot in the Bluetooth housing and remove the Bluetooth board from the upper case.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 46
Insgesamt: 23,055
