Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • The bottom left three screws are longer. Set those aside for reassembly
  2. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  3. Here are the three larger screws.  The smaller ones fit the remaining holes
    • Here are the three larger screws. The smaller ones fit the remaining holes
  4. Delicately lift the case off.  The hard drive is visible.  There is a bracket with two black screws holding it in place.  Remove the bracket and you have access to the hard drive.
    • Delicately lift the case off. The hard drive is visible. There is a bracket with two black screws holding it in place. Remove the bracket and you have access to the hard drive.
    • Remove the interface from the SATA drive and leave the ribbon connected to the mobo.
Abschluss
19 weitere Nutzer haben diese Anleitung absolviert.
jgreenmun
876 Reputation
1 Anleitung geschrieben
do you know if it's posible to upgrade the RAM memory in this particular model ?
Thanks for the guide,
Fons - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 14,505
