Einleitung
Restore sound to your laptop by replacing the subwoofer and right speaker.
Ersatzteile
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
Grab the white plastic tab and pull the battery up and out of the Unibody.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Disconnect the camera cable by pulling the male end straight away from its socket.
Use a spudger to pry the optical drive connector straight up off the logic board.
Remove the two Phillips screws securing the camera cable bracket to the upper case.
Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
Peel back the small piece of black tape covering the right speaker cable.
Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
Lift the subwoofer and right speaker assembly out of the upper case.
26 weitere Nutzer haben diese Anleitung absolviert.
4 Kommentare
I have good sound again, thanks.
2008 MacBook (aluminum).
The hardest part was starting the optical drives hold down screws, my jewelers screwdriver maginetic tip is weak.
Total time was about a half hour.
If all you have are Phillips screwdrivers, be very careful with the screws at the split of the bottom case and all of the internal ones. You may have to drop to a Phillips #000 if you don’t have a JIS #00, which appears to be the correct tool for them, based on the actual fit of the bits in my (iFixit) set.
