Einleitung
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
Werkzeuge
Ersatzteile
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the right speaker.
10 weitere Nutzer haben diese Anleitung absolviert.
