Zum Hauptinhalt wechseln
MacBook Unibody Model A1342 Lower Case Replacement
Was du brauchst
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: Schritt 2, Bild 1 von 3 MacBook Unibody Model A1342 Lower Case Replacement: Schritt 2, Bild 2 von 3 MacBook Unibody Model A1342 Lower Case Replacement: Schritt 2, Bild 3 von 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
Abschluss
74 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Antwort
Would the Macbook Pro back cover also fit this?
wow - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 58
Insgesamt: 69,738
