Zum Hauptinhalt wechseln
Einleitung
This guide is an internal private guide used as a prereq.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  2. Remove the following screws securing the right speaker assembly to the upper case:
    • Remove the following screws securing the right speaker assembly to the upper case:
    • One 12 mm Phillips screw.
    • One 3 mm Phillips screw.
  3. Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  4. Du brauchst kein Neues.
    Take $10 off $50 with
    SKIPANDSAVE10
    Jetzt speichern
    SKIPANDSAVE10
    Jetzt speichern
  5. Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card. De-route the long antenna from its channel in the rear speaker housing.
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  6. Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  7. Remove the rear speaker assembly from the upper case.
    • Remove the rear speaker assembly from the upper case.
  8. Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly. Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  9. Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  10. Lift the AirPort/Bluetooth board up off the rear speaker assembly.
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 656
