Zum Hauptinhalt wechseln
Macbook (Pro) Optical/CD Drive Disassembly
    1. Macbook (Pro) Optical/CD Drive Disassembly, Optical/CD Drive: Schritt 1, Bild 1 von 1
      • This is the optical drive once it has been removed from the computer. I think there might be some screws that I removed prior to taking this picture.
      Frag FixBot
      Kommentar hinzufügen
    2. Macbook (Pro) Optical/CD Drive Disassembly: Schritt 2, Bild 1 von 3 Macbook (Pro) Optical/CD Drive Disassembly: Schritt 2, Bild 2 von 3 Macbook (Pro) Optical/CD Drive Disassembly: Schritt 2, Bild 3 von 3
      • There is aluminium foil sticky tape that covers how the drive is split. You can see how the drive is split after having removed the tape. Now that you know how it is split you can probably make a nicer rip than me.
      Frag FixBot
    3. Macbook (Pro) Optical/CD Drive Disassembly: Schritt 3, Bild 1 von 1
      • If I remember correctly, the aluminium and hinges held the cover on. With the aluminium off you can now enter deeper into the drive.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
Thanks for posting this.
matthewkiernan - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 35
Letzte 30 Tage: 105
Insgesamt: 2,221
