Zum Hauptinhalt wechseln
Macbook 2009-2010 Unibody White Disassembly
Was du brauchst
  1. Macbook 2009-2010 Unibody White Disassembly, Removing Back Plate: Schritt 1, Bild 1 von 3 Macbook 2009-2010 Unibody White Disassembly, Removing Back Plate: Schritt 1, Bild 2 von 3 Macbook 2009-2010 Unibody White Disassembly, Removing Back Plate: Schritt 1, Bild 3 von 3
    • Remove the six Phillips head screws with J00 bit.
  2. Macbook 2009-2010 Unibody White Disassembly, Unplugging Battery from Logic Board: Schritt 2, Bild 1 von 3 Macbook 2009-2010 Unibody White Disassembly, Unplugging Battery from Logic Board: Schritt 2, Bild 2 von 3 Macbook 2009-2010 Unibody White Disassembly, Unplugging Battery from Logic Board: Schritt 2, Bild 3 von 3
    • Then Unplug the battery using a ESD Safe prying tool.
  3. Macbook 2009-2010 Unibody White Disassembly: Schritt 3, Bild 1 von 3 Macbook 2009-2010 Unibody White Disassembly: Schritt 3, Bild 2 von 3 Macbook 2009-2010 Unibody White Disassembly: Schritt 3, Bild 3 von 3
    • Once battery is unplugged, remove two Philips head screws using J00 bit.
  4. Macbook 2009-2010 Unibody White Disassembly, Removing Hard Drive Part 2: Schritt 4, Bild 1 von 3 Macbook 2009-2010 Unibody White Disassembly, Removing Hard Drive Part 2: Schritt 4, Bild 2 von 3 Macbook 2009-2010 Unibody White Disassembly, Removing Hard Drive Part 2: Schritt 4, Bild 3 von 3
    • After removing the screws and plastic cover piece, remove the hard drive then unplug from Logic Board.
  5. Macbook 2009-2010 Unibody White Disassembly, Removing The RAM: Schritt 5, Bild 1 von 3 Macbook 2009-2010 Unibody White Disassembly, Removing The RAM: Schritt 5, Bild 2 von 3 Macbook 2009-2010 Unibody White Disassembly, Removing The RAM: Schritt 5, Bild 3 von 3
    • Locate the RAM Directly above the Hard Drive. Gently push the two snaps away from the RAM cards and gently pull the ram out. You Will do this step again to remove the Second card beneath the first.
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
Gyoyo
449 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 49
Insgesamt: 8,817
