Einleitung
The Macintosh IIsi uses 4 30-Pin RAM SIMMs, installed in pairs of two for a maximum capacity of 65MB (4X16MB + 1MB). It has 1MB of RAM soldered to the logic board.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Start by turning the computer around, and remove this #0 Phillips Screw. There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Now lift these two clips, and slowly pivot the case up. You can now seperate the top of the computer from the rest of the machine. You can now seperate the top of the computer from the rest of the machine.
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB.  It has 1MB soldered to the logic board as well. Start with this SIMM.  Push these 2 metal tabs outward, then push the ram forward.  It can then be lifted out.  You have to remove the SIMMs in order, starting with the one you just removed.  You can then work your way through all of them. Start with this SIMM.  Push these 2 metal tabs outward, then push the ram forward.  It can then be lifted out.  You have to remove the SIMMs in order, starting with the one you just removed.  You can then work your way through all of them.
    • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
    • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
  5. 1st Photo: The RAM Module 1st Photo: The RAM Module 1st Photo: The RAM Module
    • 1st Photo: The RAM Module
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Chris Green
32.915 Reputation
45 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
285 Mitglieder
800 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,899
