Einleitung
The keyboard has 3 main parts, including the speaker cover, the heat sink, and the keyboard itself. You have to remove these in order to remove the keyboard.
Was du brauchst
Turn the device upside down and then locate the battery latch near the front of the device.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Eine weitere Person hat diese Anleitung absolviert.
