Einleitung
This repair guide will give instructions on how to remove the Macintosh PowerBook 1400c RAM.
Was du brauchst
Turn the device upside down and then locate the battery latch near the front of the device.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Gently grasp the ram on the far end as shown in the picture and then pull up and away from the right side of the computer
Gently grasp the factory installed RAM by grabbing each end as shown in the picture and pull the stick directly up
5 weitere Personen haben diese Anleitung absolviert.
