Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. The battery compartment is located in the front-right side of the laptop.
    • The battery compartment is located in the front-right side of the laptop.
  2. To insert the battery, gently slide it into the compartment until it clicks in place.
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  5. Carefully pull up on the front of the keyboard to pop it out from the case. Then slide the back out so the keyboard becomes nearly free.
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  6. Disconnect the ribbon that is connecting the keyboard to the rest of the computer. Pull the keyboard out and repair or replace as needed. Pull the keyboard out and repair or replace as needed.
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  7. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
    • Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
Abschluss
Ronan
54 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-1, Regan Fall 2011 Mitglied von Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 644
