Zum Hauptinhalt wechseln
Mad Catz Rock Band 4 Wireless Fender Whammy Bar Replacement
Was du brauchst
  1. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: Schritt 2, Bild 1 von 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Whammy Bar: Schritt 4, Bild 1 von 1
    • Using a size J1 philips head screwdriver, remove the four black 5 mm screws (circled in red) from the cover on the whammy bar component.
  5. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, pull off the black cover and put the spring that pops out aside.
  6. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: Schritt 6, Bild 1 von 1
    • Using your hands, pull out the rectangular circuit board from the whammy bar component.
  7. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: Schritt 7, Bild 1 von 1
    • Follow the cord for the circuit board from the whammy bar, and using your hands pull it out of the main circuit board.
  8. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: Schritt 8, Bild 1 von 1
    • Pull out the whammy bar.
Abschluss
USF Tampa, Team 1-1, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 1,669
