Einleitung
Use this as a guide to remove the motherboard so you can access the FightPad's buttons and directional pad.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Locate RS-DP-LS switch.
Pull upwards on the switch to remove it.
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
Eine weitere Person hat diese Anleitung absolviert.
