Einleitung
Use this as a guide to remove or replace the switch on the rear side of the FightPad.
Was du brauchst
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Locate RS-DP-LS switch.
Pull upwards on the switch to remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
