Einleitung
Use this as a guide to remove or replace the switch on the rear side of the FightPad.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Locate RS-DP-LS switch.
Pull upwards on the switch to remove it.
Eine weitere Person hat diese Anleitung absolviert.
