Einleitung
Use this as a guide to replace or remove the rear case.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Eine weitere Person hat diese Anleitung absolviert.
