Zum Hauptinhalt wechseln
Magellan RoadMate 1200 Back Cover Replacement
Was du brauchst
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: Schritt 3, Bild 1 von 2 Magellan RoadMate 1200 Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: Schritt 4, Bild 1 von 2 Magellan RoadMate 1200 Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ross Light
217 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 3,484
