Einleitung
You can change the battery by opening up the GPS.
Was du brauchst
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
Remove the back cover from the device by separating the back cover along its seam.
Disconnect the battery connector from the circuit board.
Pry the battery off the circuit board. The adhesive attaching it shouldn't require any other tools.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
