Einleitung
A guide to accessing the RoadMate's display.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth. Please note: this is a tedious process, but be patient.
    • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Please note: this is a tedious process, but be patient.
  2. Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
    • Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
  3. Open the back cover. Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
    • Open the back cover.
    • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
  4. Disconnect the speaker from the terminal. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Disconnect the speaker from the terminal.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Unscrew the 2 screws on either side of the board. Unscrew the 2 screws on either side of the board.
    • Unscrew the 2 screws on either side of the board.
  7. Lift the circuit board up and disconnect the GPS connector.
    • Lift the circuit board up and disconnect the GPS connector.
  8. Peel back the tape securing the display connector to the logic board. Peel back the tape securing the display connector to the logic board.
    • Peel back the tape securing the display connector to the logic board.
  9. Remove the display connector from the device.
    • Remove the display connector from the device.
    • Do not pull on the cable because you may damage it. Instead, try to pull as closely as you can to the plug.
  10. Carefully flip the circuit board out so you can get to the sensor easily. Remove the tape holding the sensor to the display and take out the sensor.
    • Carefully flip the circuit board out so you can get to the sensor easily.
    • Remove the tape holding the sensor to the display and take out the sensor.
  11. Undo the 4 clasps holding the display in place. Pop the display from the front cover. Pop the display from the front cover.
    • Undo the 4 clasps holding the display in place.
    • Pop the display from the front cover.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ross Light
175 Reputation
6 Anleitungen geschrieben
In order to remove the rubber plugs hiding the 4 screws, I found that a straight pin angled into the top of the plug can be used to lift them easily straight out and the plug is unharmed.
With the screws out, the back did not budge. I used the thinest blade screw driver in my jeweler's set to pry the case open and pushed on the plastic catches, one on each side that were holding it closed. They are visible in the photo of the back off.
Jomar - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 3,337
