Einleitung
A quick guide to accessing the RoadMate's motherboard.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth. Please note: this is a tedious process, but be patient.
    • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Please note: this is a tedious process, but be patient.
  2. Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
    • Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Open the back cover. Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
    • Open the back cover.
    • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
  5. Disconnect the speaker from the terminal. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Disconnect the speaker from the terminal.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  6. Unscrew the 2 screws on either side of the board. Unscrew the 2 screws on either side of the board.
    • Unscrew the 2 screws on either side of the board.
  7. Lift the circuit board up and disconnect the GPS connector.
    • Lift the circuit board up and disconnect the GPS connector.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ross Light
175 Reputation
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 4,837
