Einleitung
This guide will outline how to replace a Magellan RoadMate 1200 motherboard. This piece is an integral part to the system, and may malfunction or break after a long period of use.
Was du brauchst
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
Remove the back cover from the device by separating the back cover along its seam.
Remove the two screws on that are located on opposite sides of the board.
Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Eine weitere Person hat diese Anleitung absolviert.
