Zum Hauptinhalt wechseln
Magellan RoadMate 1440 Screen Replacement
Was du brauchst
  1. Magellan RoadMate 1440 Screen Replacement, Magellan RoadMate 1440 Back Cover Disassembly: Schritt 1, Bild 1 von 1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Screen Replacement: Schritt 2, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Screen Replacement: Schritt 3, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Screen Replacement: Schritt 4, Bild 1 von 3 Magellan RoadMate 1440 Screen Replacement: Schritt 4, Bild 2 von 3 Magellan RoadMate 1440 Screen Replacement: Schritt 4, Bild 3 von 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Screen Replacement: Schritt 5, Bild 1 von 3 Magellan RoadMate 1440 Screen Replacement: Schritt 5, Bild 2 von 3 Magellan RoadMate 1440 Screen Replacement: Schritt 5, Bild 3 von 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Screen Replacement, Battery: Schritt 6, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement, Battery: Schritt 6, Bild 2 von 2
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Screen Replacement: Schritt 7, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Screen Replacement: Schritt 8, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement: Schritt 8, Bild 2 von 2
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
  9. Magellan RoadMate 1440 Screen Replacement, Screen: Schritt 9, Bild 1 von 1
    • Replace the device's screen.
  10. Magellan RoadMate 1440 Screen Replacement: Schritt 10, Bild 1 von 3 Magellan RoadMate 1440 Screen Replacement: Schritt 10, Bild 2 von 3 Magellan RoadMate 1440 Screen Replacement: Schritt 10, Bild 3 von 3
    • It may be necessary to get help from a friend to hold the device stable while removing the screen.
    • Using two hands, pull back the tabs holding the screen in place.
    • Use a spudger to help use leverage to remove the screen, if necessary
  11. Magellan RoadMate 1440 Screen Replacement: Schritt 11, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement: Schritt 11, Bild 2 von 2
    • Raise the switch locking the ribbon cable in place.
    • Using twesers, pull the ribbon cable from the socket.
  12. Magellan RoadMate 1440 Screen Replacement: Schritt 12, Bild 1 von 2 Magellan RoadMate 1440 Screen Replacement: Schritt 12, Bild 2 von 2
    • With the ribbon cable removed, the screen is completely disconnected from the device.
    • To replace the ribbon cable, press the two tabs to push the head into the socket.
Abschluss
Miller Hall
325 Reputation
2 Anleitungen geschrieben
Clemson, Team 7-3, Benson Spring 2016 Mitglied von Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 410
